water leak at grab handle!!
Old 10-17-2006, 04:56 PM
truk's Avatar
Thumbs down water leak at grab handle!!
any one else have this problem! im getting a little air noise from door but also getting water from grab handle where the cover for screw is.
Old 10-17-2006, 05:13 PM
HorseHauler's Avatar
Do you have cab lights? Its a very common problem, It is usually due to one or more cab lights leeking, I had one replaced and it fixed my leak
Old 10-17-2006, 06:11 PM
bbhzx12's Avatar
My leak from the handle was the strip that the door weatherstripping mounts to on the cab, they removed it siliconed the bottom and reinstalled it and so far so good. The cab lights typically leak through the sun visor mounts.
Old 10-17-2006, 06:16 PM
truk's Avatar
no cab lights. sounds like a easy do it your self fix
Old 10-18-2006, 07:51 AM
Jeff in TD's Avatar
Here's a link to the TSB regarding door seals...
http://dodgeram.info/tsb/2004/23-003-04.htm
Old 10-18-2006, 02:40 PM
XLR8R's Avatar
Make sure that the door weatherstrip lip is on top of the grab handle/pillar trim piece and not tucked underneath it - it's a common reinstallation error.
HighTen
08-26-2004 09:00 PM
Nevada
08-03-2004 02:05 PM
Matt400
24
06-21-2004 03:49 PM
Sittenbull2
33
05-14-2004 11:54 PM
grizzly660fan
03-22-2004 12:12 PM
Quick Reply: water leak at grab handle!!
