Water in Fuel sensor. How common to replace it?
Old 05-15-2007, 04:43 PM
RoadDiesel's Avatar
Over the weekend the WIF light came on. I drained it several times,with no evidence of water in fuel. I was using PS with Marval Mys. Oil for the extra lube as many due. When I first bought the '94 CTD the wire was broken off & I sodered it back on..light comes on and off..but mostly stays on.No miss in engine for white smoke to speak of....has anyone else replaced theres? I see geno's sells them for $21.99 thanks in advance.. ( got 19.4 MPG over weekend trip of 650 miles, at 70-75 MPH )
Old 05-15-2007, 05:01 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
Yes I replaced mine...looks like they took the filter off without un-plugging it,which pulled the wires right out of the connector...For the price,I would replace it..
Old 05-15-2007, 05:23 PM
mr T's Avatar
ive lost those wires long ago haha. that silly sensor is very sensitive..If i washed my engine it would come on. I have neevr replaced I just change the filters 3 times/year. I have since then bought solid filters without a water separator as a just in case filter because the water separator tends to leak...not to meniton the solid filter is much much cheaper
Old 05-15-2007, 07:40 PM
JKM
JKM's Avatar
I'm going the MR T route , just getting a filter with a drain **** on the bottom , same as our case Tractor uses, my WIF sensor has been unplugged for months now , after the last filter change , it would not go out , so I unplugged it.
Bullet112233
04-28-2010 10:06 PM
dart3404
10-12-2009 03:35 PM
6 2 Carl
01-16-2009 06:42 PM
tyssniffen
02-11-2006 01:28 PM
Quick Reply: Water in Fuel sensor. How common to replace it?
