water in fuel light won't go off.
Old 09-21-2008, 07:23 PM
jigdog's Avatar
I installed a new fuel line from the filter to the inj pump yesterday and was working around the wif connections and maybe they got dirty or wet with fuel even though i didn't dis connect them. What can i use to clean them.
Old 09-23-2008, 08:21 AM
dozer12216's Avatar
engine cleaner, rinse, compressed air to clean and dry futher.
Old 09-23-2008, 11:19 AM
jigdog's Avatar
i pulled the plug on the sensor yesterday and cleaned it with elec cleaner and blasted it with air on the male and female and the light won't go out. there is no indication of water in the fuel. i got 1 ohm when i tested the female part of the connector. any idea what the resistance should be through the sensor itself or can i just take it out and water test it to find out if its working right?
TheNeckasaurus
08-20-2011 12:55 AM
Milwgearhead
07-20-2007 12:40 AM
izatmacb
02-18-2007 06:30 PM
97Dually
05-04-2005 09:43 PM
j28s
12-05-2002 07:33 PM
Quick Reply: water in fuel light won't go off.
