water in fuel and cam sensor code plus some
Old Apr 5, 2009 | 05:30 PM
jwb600's Avatar
06 5.9L, throwing alot of codes, hard to start, some the codes include water in fuel, cam sensor code and a couple others. tune is set back to stock and runs rough at idle. the stock fuel bowl has been removed but never had the codes before. need some help figuring out what the issues are. wiring could be messed up at the rail pressure sensor im not sure what wires go where? does anybody know what sequence these go in? im not good with wiring or electrical just looking for some help to get my truck running again
Old Apr 5, 2009 | 11:52 PM
BigIron70's Avatar
Cummins Guru
Hope this helps, Let me know if you need any other wiring diag. Good Luck, .
Old Apr 6, 2009 | 11:08 AM
jwb600's Avatar
thank you very much I printed those off to look at
elirandolph
Oct 7, 2009 06:46 AM
j
Dec 1, 2007 06:11 PM
Gabe32
16
Feb 22, 2007 06:37 PM
GaDawg
Feb 26, 2006 02:42 AM
