Wastegate Adjustment?
Old 01-14-2008, 04:20 PM
Txwelder's Avatar
Is there any way to do this on a BW S300G other than adjusting then driving and watching the gauge? Is there any type of apparatus that can be put inline with a compressor to control PSI and adjust the wastegate to my preferences?
Old 01-14-2008, 04:38 PM
schoust's Avatar
Yes you can set it up with regulated shop air that is how I did mine. Never trust what anyone tells you the waste gate is set for because it couls cost you your head gasket...........
Old 01-14-2008, 05:25 PM
Txwelder's Avatar
Thanks for the info. How exactly did you regulate the PSI? Are you just disconnecting the WG hose from the compressor housing and running the air through there? Thanks again!
sallyman1
02-10-2008 06:17 PM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
hellotbone
03-28-2003 02:11 PM
Copenhagenjunkie
01-04-2003 11:54 AM
Quick Reply: Wastegate Adjustment?
