Wastegate adjust????
Old 07-21-2003, 07:54 PM
cfm3110's Avatar
Can I "tighten" my wastegate on my '03 to allow for more boost??? My '98 had a larger-aftermarket turbo housing with no wastegate so i was getting everything I could out of the turbo without tripping sensors in the ECU and no box to "trick" the ECU...that comes out to be 29.99PSI
Old 07-22-2003, 10:45 AM
Badunit's Avatar
Re:Wastegate adjust????
Looks to be an air pressure actuator. I guess you could pinch off the signal line to the actuator and totally defeat the wastegate.
Old 07-22-2003, 05:50 PM
Mark Thomas's Avatar
Hows about taking the 2 nuts offand putting 2 washers inbetween the boost controller and housing then put the 2 nuts back on, will up the boost a hair, not sure how much though!
Ohio_Farmer
15
05-29-2011 08:26 AM
Dinner
08-05-2009 01:05 AM
adidasman23
04-23-2007 04:34 PM
Ridindirty
11-11-2006 12:05 PM
MoparRiggan
10-13-2005 11:54 AM
Quick Reply: Wastegate adjust????
