Waste Stuck?
Old 12-09-2008, 02:32 PM
scook6's Avatar
Wastegate Stuck?
I think my wastegate may be stuck shut. I'm not sure. I remember reading somewhere either on this forum or somewhere else a pressure test procedure using a valve stem and a plastic fitting. Does anyone know about this? I have searched on here and have not found anything. Anyone know about this? Thanks.
2002 Q/C 4X4 SB Auto
Old 12-09-2008, 03:39 PM
dknoch's Avatar
Hey, mine was stuck but not to bad. I sprayed it with penatrating oil and used the blow gun from the air compressor on the rubber line going into the waste gate actuator. I pulsed the air and this managed to break it free. Good luck.
Dan
Old 12-09-2008, 08:43 PM
Dinner's Avatar
Why do you think your wastegate is stuck. Are you reading higher than normal Boost Readings?
Old 12-09-2008, 10:19 PM
scook6's Avatar
I don't have a boost gauge on my truck, but I've got an over boost code. I just want to make sure it is working and not stuck.
The_g10
02-13-2013 04:45 AM
dochawken
11-27-2012 08:55 PM
Baja
01-29-2008 08:17 PM
Mopar_Mudder
09-12-2007 10:18 PM
Quick Reply: Waste Stuck?
