waste oil in a common rail?
Can I burn waste motor oil or waste hydraulic oil in a common rail? I know I have to filter it verry good. What percentage would work?
The trick is to filter, filter, filter. As long as you filter & dewater better than required, you'll be fine. I've gotten as high as 50% premixing with Kerosene. I also run an Airdog with filters for extra protection.
That would be my concern as well.... Not sure I'd recommend running it in a CR at all, but if you were going to anyways......
We find the filtering process much easier if we thin out the oil with Kerosene or Diesel before filtering it....
It all get's filtered before it gets in the tank.
I do the same thing as 9812vram. mix first then water separater, water seperater/5um filter into tank. Truck has an Airdog water seperater and 2um filter before it hits the CP3.
Administrator/Jarhead
With my fumoto drain valve, I don't have to worry about all the crud in the oil from a drain pan... I would keep my old oil jugs, and just drain the oil into them.
Then, the next time I filled the truck up, I would just pour the oil in. Three gallons of oil is 10% of 30 gallons of fuel.
I have tried to find the Cummins PDF saying what percentage of WMO that they approved, but I can't find it. I remember it being 10%...
Nope. I put magnets on my oil filter, so I'm not too worried about metals, and the five mic filters I have should catch the rest of it.
I have been wanting to build a filter setup, but I'm gonna wait until I have a beater diesel. McDonald's will bust me for stealing WVO.
