Waste Gate Rod Movement
Old 04-03-2007, 01:53 PM
mwolfe's Avatar
I Have A 98 24valve , It Seems To Have Lost Power, It Had Some Codes For The Waste Gate, I Cant Remember What They Were, But I Was Wondering If The Rod From The Wastegate Should Be Able To Be Moved By Hand, Mine Will Not Thank You For Any Help
Old 04-03-2007, 04:35 PM
Copenhagenjunkie's Avatar
The diaphram in the vac actuator probably has a hole in it which would cause the waste gate to be held shut I believe. Get a turbo master. I've had one on since 1999 w/ no problems.http://www.usdieselparts.com/turbomaster.cfm
OK re thought this, the wastegate would be stuck open which could cause low power.
low power could also be: clogged fuel filter, bad lift pump, bad injection pump, apps out of adjustment.
really need more info also: fuel pressure, any smoke and color?
Old 04-04-2007, 04:48 PM
NoSeeUm's Avatar
Post the codes and no unless something is broke or it is disconnected you can't move the wastegate by hand.
Jim
Old 10-22-2012, 05:05 PM
iwhitne's Avatar
I'm having a similar issue.. black and white smoke.. loss of power... I noticed my wastegate rod would not move even with vice grips.. I think it might be stuck open.. any ideas how to fix it and or a DIY on replacement?
Old 10-29-2012, 07:59 PM
iwhitne's Avatar
well.. my wastegate was stuck open... been spraying it with PB blaster after I drive home fo the past few days... also found out I need injectors... 176,000 on the originals! ended up going with FBD 50hp
blkt6
02-19-2014 07:14 PM
powerplant2
02-14-2003 04:36 PM
whiteknight
17
01-08-2003 10:38 PM
ox
01-08-2003 08:41 PM
Quick Reply: Waste Gate Rod Movement
