Waste Gate QQ
Waste Gate QQ
Instead of completely blocking the wastegate line has anyone tried just restricting it? That way it will still open but will be delayed.
A. Does this make sense?
2. Would it make a difference?
Just thinking out loud.
JF
JF
Originally Posted by ramcummins
You also need a boost fooler to keep your truck from de-fueling
There are also adjustable mechanical (read spring) wastegate actuators around, I think its called Turbomaster and its fully adjustable to any pressure you wish..
The boost elbows you get with plates or other upgrades do what you're describing. There is a small bleed orifice drilled in and then an adjustable pinch valve. The balance between the bleed orifice and pinch point delays the opening of the wastegate.
Mine came from TST/PDR set to 35 psi..
whiteknight
17
01-08-2003 10:38 PM
