washer fluid tank low level indicator light
Old 03-10-2009, 07:13 AM
JohnBer's Avatar
yanno.... i had this truck for 14 years, last night comming home i hit the washers, stupid dashboard lit up like the whole truck was burnin up.
it was the low washer fluid light. is there a way to tone that thing down some...... i thought the truck was self destructing and the dash was freaking out.
Old 03-10-2009, 07:55 AM
Wild4kst8's Avatar
ditto... when the low fuel light comes on, i nearly wet myself
Old 03-10-2009, 08:14 AM
RowJ's Avatar
Originally Posted by JohnBer
... it was the low washer fluid light. is there a way to tone that thing down some......
Yes! Keep bottle filled!
Sorry could not resist. Don't know of a way but now that you know what happens, probably won't be so traumatized next time.
Mines not overly bright.... maybe a retrofit from 2nd Gen CTD.
RJ
Old 03-10-2009, 10:07 AM
infidel's Avatar
It would be a simple matter to disable the warning, just cut the wire at the reservoir.
But then you could run out of fluid and not know it.
Even better system is to check the washer fluid when you check the oil.
Old 03-11-2009, 05:00 PM
Number47's Avatar
this sensor happens to be where my washer bottle is leaking so after i fill it up and use it once the light goes off
Old 03-12-2009, 08:40 AM
s-cube's Avatar
My washer fluid tank is cracked, so the idiot light reminds me every time I start the truck. One of these days I'll git a round-to-it.
EdmontonCanada
11-03-2014 01:59 PM
2006BLKMegacab
11-19-2011 10:12 AM
CamperAndy
01-03-2011 07:17 PM
06trx
01-22-2007 08:42 AM
Larry R
04-24-2006 08:42 AM
Quick Reply: washer fluid tank low level indicator light
