Wanting single stack - help
Old May 20, 2007 | 03:57 PM
03qclb5spd's Avatar
I have an 03 quad cab. I want to put a single stack in the bed, and instead of going over the corner I want to just bring it straight up from wherever it is located underneath the bed. I want to loose as little bed space as possible since I use it every day. Does anyone offer a kit that will accomplish this, or will I have to buy everything necessary and fab it up myself? I'm looking for a 6" or 7" stack as well. If anyone has pictures of this type of setup please post them as well. Thanks!
Old May 20, 2007 | 05:22 PM
jwb600's Avatar
adam I know mbrp makes a stack that is for 4" exhaust and other companies make them to fit your exhaust then it steps up to the size you want. a local guy just put one in his p-choke it goes from 4" to 5". I gave him a reducer to use and he didnt even need it. it did make for a clean install just with one clamp and no stepping up & down on sizes
Old May 20, 2007 | 05:28 PM
03qclb5spd's Avatar
p-choke, haha Jesse! I wanted to see if I could get a 5" turbo back kit, store the extra tubing somewhere and then buy some extra piping to have the single stack. That way if I ever wanted to do away with the stack and go back to a regular behind the tire tailpipe I could. I was thinking I could use Farmboy's 5" system. I don't want/need an expensive 5" system either, just one that gets the job done.
Old May 20, 2007 | 06:25 PM
53 willys's Avatar
I am going to do a full write up on that same style single stack in the next week or two... I am waiting for my 7" unchromed miter stack to be made.
but I am going to run a full 5" turbo back for mine..Should be under $250 when I'm done (most of witch is the stack)
Old May 20, 2007 | 07:59 PM
Pooter's Avatar
You should be able to make that single setup fully bolt on/clamp together with no welding. Cut the hole in the far passenger side of the bed, where you want it, shouldnt be a problem at all.
If you need help getting a parts list together, let me know, piece of cake
Old May 20, 2007 | 08:43 PM
jwb600's Avatar
[QUOTE=03qclb5spd;1516561]p-choke, haha Jesse! I wanted to see if I could get a 5" turbo back kit
well just buy a 5" downpipe. then get a straight section of pipe. I have a section now you can have. I dont need it that I know of. you can get a downpipe for under 100. but if you want to buy a system that wouldnt be a bad idea. I want to do something with mine. I may get new stainless pipe on mine. I want a different setup.
Old May 20, 2007 | 10:12 PM
03qclb5spd's Avatar
I'll give you a call sometime this week Jesse and talk about it.
I don't want to spend real big, i'm all about economy as long as it fits right and functions properly...my exhaust doesn't have to be beautful all the way from the charger....just the tip/stack.
53 I would like to see your write up when you get it finished. I should be ready within that time frame to get it done.
ramped
Oct 20, 2011 05:02 PM
5.0 Mustang Man
38
Sep 19, 2008 03:01 AM
06dodgedrw
Feb 29, 2008 10:02 PM
sburk
27
Nov 7, 2007 11:51 PM
udflyer98
May 14, 2006 04:00 PM
