Want Mega Cab with 8' Bed? Ask Dr. Z!!!
Old 10-02-2006, 01:52 AM
Tiara3100's Avatar
Saw a post over at TDR where a guy asked Dr. Z about a Mega Cab with an 8' Bed. It was suggested that if we e-mail Dr. Z with enough request for a Mega Cab with an 8' Bed, Dodge my actually get off there butts and make one. Worth a shot...Give it a try....https://www.askdrz.com/
Old 10-02-2006, 02:05 AM
XLR8R's Avatar
Wonder how long it'll be before someone swaps a long bed onto a Mega... how hard can it be?
If I had one, I'm sure I'd do it!
Old 10-02-2006, 03:17 AM
Allen Hibbs's Avatar
That thing would be rediculous big. I LOVE IT!!!!
Old 10-02-2006, 03:29 AM
XLR8R's Avatar
Wouldn't be much different, size-wise, than a F**d crewcab longbed...
Old 10-02-2006, 11:08 AM
BigDave12768's Avatar
If I had a one, I'm sure I'd do it!
It would not be easy. You would have to stretch the frame 18 inches. If not the bed would look foolish. Also since you have mount the 5'r over the rear wheels you not benefit anything from the longer bed if the frame was not stretched
Old 10-02-2006, 11:10 AM
Yes it about 18 inches longer. The Mega Cab is on a quad cab 8ft bed fram. They took 18-20 inches out of the bed and put it in the cab. So it would be about 6 inches longer than the ford crew dually
Old 10-02-2006, 11:18 AM
CTD NUT's Avatar
While we are emailing Dr. Z about the Megacab, we should complain about why the MC DRW only has a 10,500 lb GVWR while the QC has a 12,200 GVWR.....that is one thing I just don't get - a heavier curb weight, yet even LESS GVWR. I'm emailing the good Dr. about both of these MC gripes right now!!
Old 10-02-2006, 11:59 AM
XLR8R's Avatar
That doesn't sound right... my '05 Quad Cab is exactly 4" longer in the cab than my '98 Quad Cab, and it's all in the rear seat. If the Mega is another 18" over that - I dunno? I didn't think the Mega was more than 12" longer.
Old 10-02-2006, 12:00 PM
XLR8R's Avatar
Sure it'd be easy... for me out at the shop
Old 10-02-2006, 12:04 PM
XLR8R's Avatar
Dodge was just keeping the manufacturing costs of the Mega to a minimum, using an existing frame and suspension pieces for instance. With heavier-duty springs, there's no reason the Mega couldn't match the Quad for GVWR.
When I lengthen the frame for the long bed, I'll put plow-spec springs on the front and airbags in the rear.
Old 10-02-2006, 02:35 PM
CTD NUT's Avatar
I gotta tell ya, the frame and springs on the MC DRW look identical to the QC DRW in size and strength.....I see no reason why there should be any difference in the GVWR - regardless of the obvious variance in curb weights. If they are using the same components that have the same capacities, then why are they not allowed to have the same gross (maximum) weight?
Old 10-02-2006, 02:54 PM
ptgarcia's Avatar
That's what I want to know. Doesn't the 3500 quad cab SRW have the same 9900 lb GVWR as my Megacab 3500 SRW?
Old 10-02-2006, 02:56 PM
XLR8R's Avatar
That was my point - they are the same parts to save Dodge money, but the OEM reduces the GVWR to account for the extra heft of the Cab and it's passenger capacity.
Old 10-02-2006, 03:07 PM
RustyJC's Avatar
That would explain a lower payload capacity, but the GVWR should be the same.
Rusty
Old 10-02-2006, 03:10 PM
CTD NUT's Avatar
Rusty
Thank you, that was my point...
Why the heck would you LOWER the GVWR if all the hardware is the same - ESPECIALLY when the curb weight is even HIGHER?!?!
Gross weight is the total weight the vehicle is allowed to weigh with curb weight and total payload combined.
MY question is not of the payload capacity or curb weight, it is of gross weight. I recognize that an MC curb weight will be higher which will reduce payload....what I can't understand is why would the maximum allowable weight (GVWR) of the MC be so much lower?
Quick Reply: Want Mega Cab with 8' Bed? Ask Dr. Z!!!
