Want Lower EGT's
Old 08-01-2008, 06:09 PM
cstmfabman's Avatar
Want Lower EGT's
I am running an Adrenaline Quadzilla and towing 11,000 lbs. Everything else is stock, except for full gauges. I have been backing off the fuel at 1200 but an internet search suggested I could sustain 1250-1300 for long grades. Is this safe? Is there a simple way (I am leaving for Lake Powell tomorrow morning) to lower EGT's just a little? I know I need to get a bigger exhaust and possibly a turbo, but that's further down the pipe a bit. Any help would be appreciated............Ernie
Old 08-01-2008, 06:21 PM
aksparkey01's Avatar
make sure you have a clean air filter
Old 08-01-2008, 06:29 PM
AAmeeting's Avatar
You could turnbuckle your wastegate and that will bring the egt's down but you will have a lot of backpressure (9cm housing). This is most noticeable in my truck empty 80-90 mph. On the other hand around town it clears up smoke and lights instantly. You may just try it I bought a turnbuckle at lowes for 2.50 and a 7/16 wrench in the door and you could take it on and off. Tom
Old 08-01-2008, 07:54 PM
Number47's Avatar
there is nothing wrong with holding 1200-1300 degress just make sure you give your rig some good quality cooldown time
Old 08-01-2008, 10:31 PM
need12v's Avatar
And when holding those temps in the summer heat watch the coolant temp. Make sure your radiator core is clear and the level topped up.
Old 08-02-2008, 08:08 PM
rebal's Avatar
I run 1300 up most grades water /meth will bring EGTs down
smog2001
08-10-2007 09:32 AM
hemertwv
15
08-20-2006 08:34 PM
HOHN
19
07-08-2005 04:30 PM
1320
05-20-2004 04:52 PM
1320
04-23-2004 11:08 PM
Quick Reply: Want Lower EGT's
