Walbro 392 regulator problems
Old 06-24-2007, 12:56 PM
5.9Shaker's Avatar
I recently installed a walbro 392 and big line kit. I can my regulator backed down to around 15psi but then I can't lock it there so it won't leak in order to get it not to leak it has to be around 21psi. has anyone ran in to this problem?
Old 06-24-2007, 01:55 PM
greasemonki's Avatar
I guess they changed the regulator from when I bought my unit. Mine was "non adjustable" in that there was no adjusting nut. I had to take it apart and tweak the spring and spacers to get my desired fuel pressure. Maybe you can do the same on yours?
Old 07-22-2007, 04:30 PM
JollyGQ's Avatar
Where did you buy your kit at? I am looking to buy the Walbro from Ebay with the install kit and the relocation kit from Geno's...but neither one mentions a regulator in the kit. Thanks
Old 07-22-2007, 05:48 PM
Rpainter's Avatar
I bought mine from richard at glacier in his kit it has a bypass for fuel pressure to adjust you have to change a shim or a spacer
madhat
47
01-26-2008 09:06 AM
d0dg301
08-06-2006 11:13 PM
Austin'sDodge
22
07-30-2006 09:31 PM
streetsmoker
24
05-07-2006 12:26 AM
Dodge Demon
02-27-2006 06:47 PM
Quick Reply: Walbro 392 regulator problems
