walboro 392 kit from wideopendiesel
Old 07-08-2007, 05:02 AM
stock659's Avatar
since I put on the kit from wideopendiesel I have had a couple pressure flucuation changes. I just replace my fuel filter today. I was wondering if anyone that uses this set-up has cleaned the prestrainer and how is it done?
Old 07-08-2007, 12:13 PM
MARKY MARK's Avatar
I have the same kit from wideopendiesel and also have had some pressure flucuations. When I drive, the pressure drops from 18 to 16 with normal driving throttle. When I give lots of throttle, the pressure will jump up to about 20 psi. Not sure if this is normal or not. Just in the last few days when I first fire up the motor, pressure shoots up to about 23 psi and drops down when I start to drive. Never did that before since I put the kit in back in February. Not sure what to check.
What kind of flucuations are you seeing?
Mark
Old 07-08-2007, 01:24 PM
stock659's Avatar
The pressure at my vp-44 is 16 to 17 at idle, 14-15 at 60mph 12-13 at wot normally. Sometimes it will drop to 10 while accelerating and stay there for a while, then bounce back to normal. I not overly concerned since this is much better then the stock carter pump was operating at and still better pressurers than the intank pump.
Old 07-08-2007, 05:09 PM
MARKY MARK's Avatar
I'm going to adjust the regulator when I get home week after next. Going to Hawaii tomorrow for a week. I'd like to see my #'s where yours are.
Mark
stock659
11-17-2009 04:15 PM
stock659
01-04-2008 03:50 PM
stock659
12-31-2007 04:37 PM
stock659
07-25-2007 09:48 PM
Sea01Cummer
119
01-27-2006 08:38 PM
Quick Reply: walboro 392 kit from wideopendiesel
