wait to start light
wait to start light
Here's a brain teaser. When I turn on the ignition the wait to start light does not come on. It takes ten seconds or more to come on. The engine will not start until the wait to start light comes on. I have a friend with a cummins 5,9 and he too has the same problem. When the light comes on you can hear the lift pump energize and the engine will start. It also brings on the check engine light when this condition occurs. Sometimes the wait to start light comes on with the ignition as it should and the engine will start right away?
Has anyone else experienced this quirk??
The ECM mounted on the side of the engine is responsible for illuminating the "Wait to start" lamp. It goes through a self check when it gets a start signal from the key switch.
There are only a couple of reasons the WTS lamp takes a long time. One is the ECM is faulty and when doing its self check it will find a problem that can correct itself after several seconds. The other common problem is the ECM does not receive good 12 volt power and this may be fixed by replacing the relay in the power distribution center (fuse box) on the fender well.
If the problem is in the ECM it may eventually need to be replaced. In my opinion the ECM can become intermittent because of a part on the circuit board failing to make a good electrical connection or just changing value due to many heat/cool cycles. The ECM computer looks for nominal voltage values when it is powered up and if something is out of range will not pass the self test keeping the lamp off.
Try the relay first.
bfarrell
11-30-2005 03:23 PM
