VP44 puller information
Old 04-14-2007, 08:32 PM
tbelue's Avatar
I would like to know who could give me the specs on the injection pump
puller. I had read some had made them from a piece of plate and tapped the holes in them. I mainly need the hole spread I can figure out the rest.
TB
Old 04-14-2007, 08:45 PM
Rsquared28's Avatar
You don't need any special puller for a VP44. Just a standard bar type puller will do the job. Usually a steering wheel puller works just fine.
Old 04-14-2007, 09:04 PM
bnold's Avatar
Here's mine!! Worked great!!
Old 04-15-2007, 12:17 AM
bentwings's Avatar
There was a post quite a while ago where a guy took the rear lift ring off the head and drilled a hole in it and tapped it and used a couple sockets for spacers.
Bottom line is that it doesen't take much of a puller. Just be very carefull that you do not drop the nut and washer on the front side and be very careful of the shaft key onthe back side. I used a short magnet and it worked fine.
Old 04-15-2007, 05:09 AM
tbelue's Avatar
Thanks for the photo I will make on tomorrow.
Old 04-15-2007, 07:32 AM
Administrator / Scooter Bum
Shovelhead's Avatar
I used my steering wheel puller when I replaced my VP.
turbo lcc
15
07-19-2003 01:37 AM
GO 4LO
12-27-2002 04:46 PM
Quick Reply: VP44 puller information
