VP Error Codes
Old Feb 19, 2008 | 09:08 AM
jasonlee08's Avatar
VP Error Codes
Does any one know where i might can acquire a list of the engine error codes and what they mean that run a VP44?
Old Feb 19, 2008 | 09:52 AM
xtoyz17's Avatar
http://wiki.dieseltruckresource.com/wiki/Computer_codes
These?
Old Feb 19, 2008 | 11:06 AM
91rangerturbo's Avatar
Here is another source of them
http://www.idahobombersforum.com/tip...rror_codes.htm
Old Feb 19, 2008 | 12:37 PM
jasonlee08's Avatar
do either of them give the companion code? or do you know it?
Old Feb 19, 2008 | 01:03 PM
xtoyz17's Avatar
Hope this helps:
If you check for fault codes with a scan tool that is only capable of pulling codes from the PCM side, the only code you typically get is a P1693. This code is a companion code, meaning that the PCM has been informed that there is a problem in the engine ECM, but the ECM has not relayed the exact code and you will have to communicate directly with the ECM to find out what the exact code is. This will take a scan tool or Cummins Insite that is capable of communicating with the engine ECM.
Old Feb 20, 2008 | 03:03 PM
jasonlee08's Avatar
that seems like it should work..... see what the deal is people bring me the vp's and tell me it read such and such code and i have no clue what that code is... when i read out the pump psg i get different codes and i know exactly what the pump codes mean just not the engine codes they tell me
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
spitzair
Nov 24, 2002 02:19 AM
