VP 44 Injection Pump
Old 12-09-2008, 11:49 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
If the VP-44 is going out, will a code set in the OBDII system? I'm trying to track down a slight intermitted miss at heavy throttle. I've narrowed it down to either the IP or an injector itself.
Old 12-10-2008, 05:41 AM
Fishin2Deep4U's Avatar
The answer is sometimes.
Not all injection pump failures or pending failures throw a code.
Dave
Old 12-10-2008, 12:55 PM
93beater's Avatar
it should throw a code... and be careful cuz if ur LP goes bad and your driving your IP can suck fuel enuf to burn it out..... there is a good site for codes that can be found by typing dodge cummins codes in on google. good luck
Old 12-10-2008, 01:08 PM
JPR Ram's Avatar
OK, thanks. As for the LP, I'm currently running a Raptor; 21 psi idle, 18-19 posi cruising and 15-16 psi at WOT. I do have a code reader that even defines the code; but it just keeps saying "No Faults". I'm honestly swaying towards an issue with one of the injectors. I just may swap them out for my old stock injectors for testing.
Old 12-10-2008, 04:04 PM
Dinner's Avatar
Are you able to get your hands on on Solus(sp) Snap On scanner, or something along those lines? These scanners are able to shut off injectors so that you can see if one is bad. However maybe this is only at an idle, and you are finding problems at WOT, or just hard acceleration?
Old 12-10-2008, 04:42 PM
JPR Ram's Avatar
Mostly with hard acceleration situations and only when in the midrange. The thing is though, it's real intermitted. It happens about 75% of the time under the above described situation. It doesn't happen at idle or even at WOT at higher RPM.
Old 12-11-2008, 11:41 AM
93beater's Avatar
on my brothers 02 cummins it did something like what your describing... took us forever to figure it out but we eventually narrowed it down to the injector getting clogged on cylinder #6 and only delivering the right ammount of fuel 50% of the time. it also didnt throw a code... get your injectors pop tested. the local dodge house can do it... dosent cost that much to my knowledge... does it act up more when its hot or cold? the snap-on scanner would also be grand idea... great for diagnostics... if you can afford it....! costs more than i paid for my 12v! good luck
tommurray
02-23-2014 10:38 AM
billygoat02
12-29-2005 11:03 PM
adgr71
11-28-2005 07:34 PM
Yukon Dodge
18
07-01-2004 10:08 AM
cheng
06-22-2004 12:01 PM
Quick Reply: VP 44 Injection Pump
