Voltage Regulator Output
Old Sep 18, 2006 | 03:40 AM
dieseldel's Avatar
Does anybody know what the specified charge voltage to the battery is supposed to be? Trying to determine if my voltage regulator is working correctly.
I'm showing 13.8-13.9 most of the time, which is too high for a float charge and too low for the absorption charge phase. Is this voltage typical on 2nd generation?
I don't know what kind of battery was original. I assume it was Sb/Sb (Lead-Antimony on each plate), as Ca/Ca (lead-calcium each plate) like GM uses would require an even higher charge voltage to get any kind of life from the batteries.
Thanks.
Old Sep 18, 2006 | 09:56 AM
ccmckee's Avatar
The charge voltage will vary with the ambient temperature anywhere from 13.5 -14.8, this controlled by the pcm. I can see the difference in the winter as the volt guage will be a little higher than it is in the summer.
Old Sep 18, 2006 | 11:43 AM
dieseldel's Avatar
Ok, thats what I wanted...thanks.
I guess my PCM is normal then. I see it vary with temperature like yours too.
Unfortunately, "normal" is not healthy for a set of batteries.
Maybe I'll add an external regulator that can be adjusted instead of the PCM. Batteries sulfate badly with this kind of charging system in our high temps.
Old Sep 19, 2006 | 03:43 PM
SoTexRattler's Avatar
The battery temperature sensor is under the driver side batt tray... You might play with altering the sensor's resistance value to "tweak" the desired battery voltage rather than delve into the PCM and it's built-in voltage regulator .
The underhood temps are brutal for virtually any component, especially L-A batts...
K.
RonA
Dec 4, 2006 09:50 AM
Deer716
Oct 5, 2004 09:29 PM
Gabe
May 4, 2004 11:44 PM
freeloader
Mar 28, 2003 09:00 PM
hellotbone
Oct 9, 2002 02:20 PM
