voltage as a function of speed
Old Jul 21, 2006 | 12:30 AM
Barrett_Fodder's Avatar
I am trying to find a source for a voltage output that is a function of speed. I would like to wire up a speed sensitive volume control for the stereo in the truck. In order to do this i need a voltage source that will increase as speed increases. My first thought i that most likely their should be some variable volatge output running the speedometer. If anyone know for sure or knows either what that voltage is or of another voltage source that is dependant on speed i would very much appreciate it.
Thanks,
Dan
Old Jul 21, 2006 | 09:39 AM
TonyB's Avatar
It appears wiring diagrams for '04 can still be had on DC Bodybuilder site .
That's where I'd start.
HTH
Tony
Old Jul 21, 2006 | 11:17 AM
Jeff in TD's Avatar
The vehicle gets it's speed reading from a hall effect sensor mounted on the rear dif housing, so that wouldn't be the varying voltage you are looking for.
Old Jul 21, 2006 | 02:14 PM
RamWheelsBy4's Avatar
Very interesting mod. I completely understand the need. Plz let us know how it works out.
Old Jul 21, 2006 | 03:54 PM
timcasbolt's Avatar
Is that anything like what they do on motorcycles?
Old Jul 21, 2006 | 04:55 PM
Deesil's Avatar
Muted User
mount a windmill to your hood
Old Jul 21, 2006 | 06:15 PM
bigdav160's Avatar
Hall effect?? Are you sure???????
I believe it is a PM generator that does deliver a variable A/C voltage.
Old Jul 21, 2006 | 07:22 PM
Jeff in TD's Avatar
I could be mistaken, but that's sure what it looks like?
Old Jul 21, 2006 | 11:57 PM
windmill it is...
Thanks for all the replies. Ill check the above link and see if I can find anything for a voltage source there.
Ill post an update if i find anything
Old Jul 22, 2006 | 06:03 AM
crobtex's Avatar
I have a '95 Z71 that has the variable volumn control. I have no idea how it works, but GM it might be a good place to look for info.
Old Jul 22, 2006 | 09:17 AM
Jeff in TD's Avatar
I think it's a super-neat idea, and let us know if you figure something out.
The Impala I drive at work has speed sensitive volume that can be set to off, high, or low. I'd guess the powertrain module gives the stereo some kind of signal?
Old Jul 22, 2006 | 10:01 AM
Christov's Avatar
From what I recall a speedometer works on the frequency that it is receiving. This is usually picked up from a hall effect pickup either in the transmission or somewhere on the driveline. This is really only varying the frequency and not the voltage to the speedometer. I don't know if you could use a type of pitot tube for an airplane or not. These usually have a plunger in them that moves forward or backwards depending on the amount of air pressure (speed) in front of the plunger. This would be a variable source, but I don't know if it would work for your particular application.
Old Jul 22, 2006 | 10:19 AM
well pin 27 on the c2 connector is the vehicle speed sensor, and i have a couple of other possibilities as well. If i can fid my multi meter ill go for a drive and see what i can find.
thanks for all the replies so far as well.
imbodie
21
Jan 8, 2024 08:49 AM
atch
Nov 1, 2010 02:45 PM
gcdodge
Aug 18, 2005 03:39 PM
jred
Sep 25, 2003 06:07 PM
Lightman
Jul 15, 2003 11:34 AM
