Volt Meter
Old 02-10-2010, 08:28 PM
saltfever's Avatar
Volt Meter
When we start our engine the volt meter only registers about 12volts. Once under way the meter registers on the 14 volt side. Start up needle to the left, under power, to the right. I know our 5 year old factory batteries are getting a little weak and need changing soon but is this a normal condition?
Old 02-10-2010, 10:57 PM
HOD-ISB's Avatar
Yes, different models illustrate the effects of the grid heaters differently. Some years cycle the volt meter in correspondence with the grid heaters cycling. Some models just show around 12 volts until the grid heaters stop or you reach 20 mph.
Old 02-11-2010, 04:40 AM
saltfever's Avatar
Thanks for the reply. I have noticed the lights dim and get brighter until the engine has warmed up.
Old 02-11-2010, 08:41 AM
AH64ID's Avatar
The grid heater will run for 2 minutes or until 18mph is reached.
Old 02-11-2010, 09:31 AM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
Really? They continue for that long! I never knew....
My volts drop to around 12-13 and it seems they stay until what seems like a relay or something kicks on and the alternator starts putting amps into the batteries.
I thought it was a voltage reg issue.
Old 02-11-2010, 11:36 AM
tryNto's Avatar
A lot of people report this situation, mine has always done it. Reads just battery voltage, then in a short time the Alt. kicks in.
Festus
03-02-2011 01:00 AM
chuckybones
07-22-2008 05:55 PM
Dynocon
10-12-2005 08:26 PM
12valve@heart
03-07-2005 12:19 AM
Dieseldude4x4
01-04-2003 03:07 PM
Quick Reply: Volt Meter
