Vibration ?
Old 03-23-2011, 03:50 PM
shep1's Avatar
Vibration ?
I'm getting a slight vibration through the steering wheel and can feel it in the fuel peddel. It starts at aprox 48MPH through 60MPH. It's most noticable at 55MPH. I've had the tires rotated and balanced and the tires balanced a second time with maby a slight inprovement but it's still there. Any Ideas??
Old 03-24-2011, 05:12 PM
bookem's Avatar
I had the exact same thing. Turned out to be the far rear u-joint.
Hope this helps,
Dan
Old 03-25-2011, 02:59 PM
shep1's Avatar
You mean the one at the rear differential?
What year is your truck?
Old 03-25-2011, 04:43 PM
icefishers's Avatar
I have the same issue. Was going to do a little investigating this weekend to see if I couldn't find the problem. I'll let you know if I find anything.
Old 03-25-2011, 04:47 PM
CRToney's Avatar
Get centramatics and some vibration will go away.
Old 03-25-2011, 05:32 PM
bookem's Avatar
Yes, the one at the rear differential. My truck is an 06 MegaCab.
Old 03-25-2011, 09:58 PM
jhenson's Avatar
My first set of joints were toast in under 20k miles. Had a little vibe at speed but hit the breaks to slow down and Holy God the whole dash would shake like the whole truck was gonna fall apart. Those AAM joints are junk....at best. Get Spicer Life's or some Precisions....I've had very good luck with Precisions but others swear against them.
I guess it's a crap shoot.
Old 03-25-2011, 10:35 PM
.boB's Avatar
Get the truck up to about 70mph, put it in neutral, and let it coast down until the starts. Let it keep coasting until the vibration stops.
If the vibration is the same, it's probably in the suspension, drive shaft, or diff. If the vibrations changes significantly, it's probably the engine, trans, or transfer case.
dodgedsl03
01-18-2007 10:08 PM
Davidp
03-19-2003 11:29 PM
spitzair
03-11-2003 11:06 PM
deere nut
12-01-2002 08:09 AM
chdiesel
11-03-2002 04:39 PM
Quick Reply: Vibration ?
