Vibrating when accelerating at 0km to 15km
Old 06-03-2008, 10:38 AM
megacabby's Avatar
Unhappy Vibrating when accelerating at 0km to 15km
My 2007 Megacab vibrates between 0KM to 15KM when acclerating and vibrating goes away after. The dealer has put an order in for some U-Joints however, U-Joints (-400) are on back order. Will the the repalcementof U-Joints take care of this issue or are we facing with a possible driveshaft or it possibly the anti-slip? Has anyone experienced this..please advise.
Old 06-03-2008, 10:58 AM
ptgarcia's Avatar
Very common issue. Most attribute it to drive line angles. You need to shim the intermediate bearing for the rear drive shaft. I'd do it in 1/4" increments until the vibration disappears or is minimized.
By the way, my truck does it also. But it doesn't bother me enough to do anything about it.
Old 06-03-2008, 03:17 PM
northernwheeler's Avatar
Wait and see if the u-joints fix it. Had the same issue, joints looked ok, but one had seized caps on it and caused a strange vibration.
Old 06-03-2008, 05:06 PM
1stdodge's Avatar
My Mega Cab has vibrated since day one. I have 50k on it and it hasn't gotten any better or worse. Like ptgarcia says, its related to the driveline geometry. If I throw my ATV in the bed or tow, its way less noticable.
Old 06-04-2008, 06:49 PM
mega06's Avatar
new ujoints fixed my 06 mega the ujoint were upgraded must of had a problem.
Old 06-09-2008, 10:31 AM
Mutt68's Avatar
I have a vibration or shutter with my 06 Mega Cab only from a dead stop to 15 - 20 MPH. It is alot more noticable with mt fifthwheel attached. After 15-20 MPH she is smooth. Is it U-joints or intermediate bearing? I want to take it in to the dealership under warranty but they do npt impress me with there work.
Matt
Old 06-09-2008, 01:26 PM
DieselBoy20's Avatar
I also get a real shutter when accelerating hard with my bumper pull trailer hooked on in 3rd or 4th gear. Any answers for this?
Old 06-09-2008, 09:23 PM
Equalizer 2's Avatar
Crawl under your truck and look for a line of grease thrown from the u-joint. If you find a line you definitely have a bad u-joint. If you don't find a line then it could be drive line geometry or it could still be a bad u-joint.
If it is more pronounced with a 5er on or even a TT then it is probably a u-joint as the weight of the 5er or TT is supposed to "fix" the drive line angle as there is weight on the truck changing the angles.
SolarYellow05
04-09-2006 05:39 AM
BigBlue
13
12-12-2005 10:47 PM
jschintgen
09-14-2005 12:00 PM
Hoss
08-11-2005 04:51 PM
Quick Reply: Vibrating when accelerating at 0km to 15km
