Very high fuel pressure on deceleration
Old 04-23-2007, 11:06 AM
Baja's Avatar
I am wondering if damage can occur with this high pressure. I run on WVO, and when I am going downhill on the freeway, foot off the pedal, my fuel pressure will climb up to 45-50 psi, until I step on it again. If I switch to diesel on the same descent, the pressure will instantly drop to 30 psi, normal. Is this high pressure OK, or is there the possibility of internal IP damage?
Old 04-23-2007, 06:51 PM
infidel's Avatar
The Bosch specialist I talked to several years ago told me anything over 45psi is tempting fate...
My guess is the higher viscosity of the WVO makes it harder to pass though the overflow valve.
Old 04-23-2007, 09:42 PM
Baja's Avatar
Thanks, I thought it was a viscosity issue as well. I'll have to pay attention to it.
Old 04-24-2007, 05:10 AM
diesel don's Avatar
I did the spring trick (lenghten) it to about one half inch ( it has 117,000 Mi. on it at this time) I run 35-40 pounds fuel presure all the time even at idle and WOT.
OR Mega Cab
16
09-10-2007 11:36 PM
AlpineRAM
09-08-2006 07:32 PM
spudwrench
04-19-2005 10:30 PM
Joe N.
11-09-2004 11:48 PM
Hottrodjim
04-04-2003 04:19 PM
Quick Reply: Very high fuel pressure on deceleration
