Vent visors + tow mirrors?
Old 08-13-2008, 09:51 AM
xtoyz17's Avatar
Will this work? Packages always say "non tow mirrors". Are the shape of the bases different? Anyone do this successfully?
Thanks,
Shawn
Old 08-13-2008, 06:09 PM
spooled142's Avatar
I have the tow mirrors and vent visors but my vent visors are the "in channel" ones whice means that they tuck up in between the window and door
Old 08-13-2008, 06:31 PM
braxton357's Avatar
By "tow mirror" are you referring to 3rd gen flip out mirrors installed on a 2nd gen? If so, I've got a set on my truck with the gts ventgaurds. The curve for the mirror base at the very end is slightly different, added some 3m double stick foam tape like they include on the visor to that area and pressed hard for a few minutes. Fits fine now.
Old 08-13-2008, 08:46 PM
xtoyz17's Avatar
Yes those are the ones. Either manual ones, the new kool vue ones, or the swapped bases third gen/ second gen hybrid.
Does GTS offer visors for quad cabs as well, or no?
Thanks,
Shawn
Old 08-13-2008, 09:23 PM
torqmonster's Avatar
I have Kool vue's and lund vent visors, I didn't even notice much of a difference. Not sure about quad cab visors, I've been looking for some myself.
Old 08-13-2008, 09:58 PM
Racing_Joe66's Avatar
braxton357
what is all needed or to be done to mount the 3rd gens on the 2nd gen trucks?? i have a 97 and want to mount those mirrors??
thanks
Old 08-13-2008, 10:05 PM
braxton357's Avatar
Here is a decent writeup that I've seen. http://www.klenger.net/dodge/2nd-gen...g-mirrors.html In my case, my truck (99) had power/heated mirrors, but the wires/connector from the new power/heated mirrors were not the same. I've done plenty of automotive wiring in my life, efi swaps, etc... but this was still a PITA trying to figure out which wire went where. None of the matching wires were the same color and my FSM was no help. Somewhere I wrote down which wire went to which, and if I can find it I'll post up. Also used a press to compress the spring and put on the retainer. I'm not sure how you would do it otherwise. You'll see what I mean when you take apart the base.
Thanks,
Shawn
Not sure if they do or not. My truck is a qc, but I only did the fronts. Might try JC whitney.
Old 08-13-2008, 10:28 PM
thanks. let me know if u find anything on the wires.
Old 08-13-2008, 10:59 PM
Tate's Avatar
When I bought my vent visors, they didn't make any for the quad cabs since the windows open from the rear, and not from the top like a typical window.
I have ventvisors on both trucks, and the tow mirrors on both, and they fit fine. You can see they aren't designed for the bigger base, but its not enough to concern me at all.
Old 08-14-2008, 06:45 AM
xtoyz17's Avatar
They now make power heated mirrors for 2nd gens that are a direct replacement.
Old 08-14-2008, 09:11 AM
Highrlr's Avatar
Hope this isnt too much of a highjack, but anyone know where I can get the in-channel visors for my '02 with the tow mirrors?
Old 08-14-2008, 10:06 AM
xtoyz17's Avatar
Weather-tech makes a nice set. Any in-channel visor will work. My problem is that I want stick-ons.
Old 08-14-2008, 10:38 AM
xtoyz17
who makes them?? i haven't seen any!! let me know asap.
thanks
Old 08-14-2008, 11:13 AM
xtoyz17's Avatar
xtoyz17
thanks
"Kool-Vue". Search that on here and you'll find a lot. The gist of it is that you would still have to hardwire because you didn't have heated mirrors as an option. Also, because you didn't have tow mirrors to begin with you'll need some additional hardware, but that's cheap.
http://cgi.ebay.com/ebaymotors/DODGE...mZ280254280425
That's an auction for a set. Also, they offer the plates for a nominal fee. No I don't work for them, no this isn't a sales pitch
There is a pretty lengthy thread on here somewheres, with lots of folks running them who are very happy with them.
Shawn
Old 08-14-2008, 11:55 AM
spooled142's Avatar
I have EGR visors and they dont rattle at all even with the window down doin 80 mph. Check them out at www.egrusa.com
Quick Reply: Vent visors + tow mirrors?
