variable geometry HX40V compr map up for grabs
Old Mar 26, 2006 | 04:25 PM
Artsi_L's Avatar
Found a HX40V charger compressor map, used in a 7,8 liter IVECO engine. It even has a comparison curves between wastegated and variable geometry chargers. Neat.
Please do not fail to click the 'view full size' text at the bottom of linked page.
http://community.webshots.com/myphot...ecurity=zGyKvq
Old Mar 26, 2006 | 05:45 PM
NMCTD's Avatar
nice find!!! I wouldn't mind trying out a VGT once I get some goodies for my truck
Old Mar 27, 2006 | 12:56 AM
Ph4tty's Avatar
I just wish a compressor map meant something to me
Presure vs air flow makes sense, but the circles around them?
I aced calculus, but am still clueless. Sombody pm me and beat some sense into me piz
Thanks for posting artsi- nice find
Old Mar 27, 2006 | 02:02 AM
Artsi_L's Avatar
The airflow axis has a cubic meter format, rather than lbs/min as what Holset usually uses.
I visited following web page to find attached formula to do conversion to lbs/min flow. (Note, formula has flow per second, and compressor map has flow per an hour !!!)
http://www.ztechz.net/id6.html
1 m³/s = 2118.88 cfm, 10 lb/min = 144.718 cfm
Old Mar 27, 2006 | 09:01 AM
HOHN's Avatar
Circles are "efficiency islands" and show the efficiency: 60%, 70%, 80% etc.
The other radii are shaft speed in RPMs (80,000; 90K, 100K, etc)
A compressor maps relates shaft speed to 1) pressure ratio 2) airflow, properly listed in POUNDS of air (mass), and 3) efficiency
jh
Old Mar 27, 2006 | 03:09 PM
high country's Avatar
this will pretty much fill every last bit of brain space you have left with turbo information.
http://www.turbomustangs.com/turbotech/main.htm
hope ya got a couple minutes.
Old Mar 27, 2006 | 11:02 PM
Artsi_L's Avatar
This site ain't too bad either:
http://www.gnttype.org/techarea/turbo/turbopage.html
PeterT
77
Sep 18, 2006 08:16 PM
Artsi_L
Feb 5, 2006 11:47 PM
PeterT
Mar 2, 2005 09:29 AM
1ST GEN.
Oct 5, 2004 05:52 PM
admin
Apr 13, 2003 02:51 PM
