Vapor Lock?
Old 06-28-2009, 03:11 PM
marine4life's Avatar
Vapor Lock?
I just moved to Aurora Co from North Carolina. I have been romping around town(a little more smoky than before) and with the aggresive tunes i can get the truck to die if I hit the throttle hard and let off. I let the truck sit for a about 5 secs and then it'll start right up, no codes, and the truck doesn't seem to run any different. Is this a huge problem?
Bryan
Old 06-28-2009, 11:01 PM
Tate's Avatar
Its common with VP's and large injectors. Surprised you never had this issue before.
Old 06-28-2009, 11:05 PM
1-5-3-6-2-4's Avatar
I could kill my old 24v '98 on command with the DDP comps I had in it. a few times it was hard haaard restarting.
Old 07-01-2009, 03:48 PM
Well good to know, guess i'll just keep the pedal to the floor then. Thanks for the responses guys.
Bryan
Old 07-01-2009, 03:52 PM
the only way to avoid the problem is to feather the throttle when comeing out of a WOT pull for any length of time, stab the clutch and free rev it until your sure it won't die when you re-engage the clutch. you just learn to drive around the problem. and it'll still bite you every now and again.
Old 07-01-2009, 03:58 PM
Mike D's Avatar
Bryan, How's that charger working out for you?
Old 07-03-2009, 01:06 PM
haven't installed it, it's still sitting over at chris's place in north carolina. Im in Aurora Colorado and my 62/12 isn't spooling very well, probably gonna sell it and step up to a full size s400 for a good twin setup.
Old 07-03-2009, 11:08 PM
Mike D's Avatar
That's too bad, I really wanted to see how that charger would have run in your truck but I know the high alt. would be no fun. I don't think you'll have a problem selling it.
Old 07-04-2009, 12:50 AM
psd tuner's Avatar
yep same here....wot for a while truck dies or has a irratic idle. got to tap the skinny pedal after pressin it all the way down.
T & T
05-29-2014 08:03 PM
The Sarge
09-25-2012 07:01 PM
pwrtripls1
09-15-2010 04:18 PM
12valve@heart
03-30-2008 02:52 AM
1st gen Hobie
10-20-2006 11:03 PM
Quick Reply: Vapor Lock?
