valve cover leak
Old 11-26-2010, 08:55 PM
97catintenn's Avatar
valve cover leak
I need to replace the orings on the valve cover bolts. I bought new valve cover gaskets, but they didn't come with the orings for the bolts.
Any ideas on where to get them?
edited for future reference: They are a #7 O-ring (1/2od x 3/8id x 1/16)
Old 11-26-2010, 08:59 PM
bgilbert's Avatar
Cummins. I've never replaced those o-rings and they don't leak? If I just had to have them, I would try matching them up from a hardware store's assortment of o-rings or the like.
Old 11-26-2010, 09:09 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
Yep I'm running hardware store O-Rings on my junk.
You can also get an assorted box of O- Rings from Harbor Freight.
Old 11-26-2010, 09:11 PM
Two of the valve covers have oil all over the top and sides, so I'm assuming its the oring. Or is it a grommet?
Old 11-26-2010, 09:12 PM
Thanks pulltilbroke, I run over there tomorrow and see how they do. Mine are so bad out of shape that I thought they were shaped more like grommets than orings
Old 11-26-2010, 09:29 PM
Jim Lane's Avatar
Go to the hardware store and get them, they are just a common o-ring, the look can be deceiving.
I went to Dodge and they wanted like $5.00 each for them.
You can get a Nitrile o-ring kit for about $5.00 or get them in the plumbing department for about 25 cents each.
Jim
Old 11-26-2010, 11:48 PM
Received 1,332 Likes on 862 Posts
I bought my valve cover gaskets through NAPA, and they came with the the O-rings.
Old 11-27-2010, 12:30 PM
92smokin blacky's Avatar
yeah just get an O-ring kit and use ones that fit, you'll probably use a few more O-rings on the truck too so might as well get a kit that has a bunch of different sizes.
Old 11-27-2010, 09:43 PM
Thanks for all the replies guys. I would say that I can't believe that I've made this long without a generic o-ring kit, but the reason I have, is because I assumed they were generic. And I also thought the ones I would need would be specific to application in size/diameter.
Also thanks to the poster below. I was upset that I didn't get an o-ring with my valve cover gasket, so I dug out the receipt and along with it...I pulled out an o-ring! I just overlooked it before...(so Adv@nce Auto also includes o-rings)
Exekiel69
08-04-2008 11:43 PM
kas83
01-17-2008 08:31 PM
Delectric
23
07-29-2007 11:58 AM
displacedtexan
17
12-07-2006 09:13 PM
suzukiZrider
01-13-2005 08:20 PM
Quick Reply: valve cover leak
