valve adjustment
Old 11-23-2003, 04:15 PM
20014x4's Avatar
valve adjustment
I want to adjust the valves on my truck. Have never done it on a ctd. I've been a mechanic for over 20 yrs. dont trust mechanics in shops. (past problems). I need valve lash measurements in. & ex. also tdc marks. thanks.
Old 11-23-2003, 04:42 PM
StakeMan's Avatar
Re:valve adjustment
intake = .010
Exhaust = .020
TDC mark is on the VP44 gear. Twist the crank case breather off and use a mirrior.
Old 11-23-2003, 04:53 PM
20014x4's Avatar
Re:valve adjustment
thanks stakeman. now i've got a job for tonight. If its not too cold out.
Old 11-23-2003, 05:00 PM
Dr. Evil's Avatar
Re:valve adjustment
How many miles? The severe service schedule says 135k for a 24V & 150k for normal service.....
Old 11-23-2003, 05:05 PM
20014x4's Avatar
Re:valve adjustment
I've got about 60,000. runs great. just want to make sure all is ok
Dr. Evil's Avatar
Re:valve adjustment
Never hurts....
Old 11-23-2003, 08:48 PM
James Lucas's Avatar
Re:valve adjustment
There is a sequence that has to be followed... With the marks lined up you do the first cylinder (intake and exhaust) and then you follow a sequence. Then after that sequence is done you rotate the VP44 gear to all the way down and follow another sequence. Isn't this correct? I don't know the sequence though ???
James
Old 11-23-2003, 08:58 PM
thumper 549's Avatar
Re:valve adjustment
I do it the stupid way and follow the fireing order, that is I find one with valves closed ,do that one and then next one and so on just depends as to which one you start with...yes i know there is the ez er way but i like checking ever one at t.d.c for good measure.
Old 11-23-2003, 10:40 PM
DRD
DRD's Avatar
Re:valve adjustment
I can post the easy way if you really want it (written down in the garage). When I do mine I usually use a dial indicator to check the lash before I bother getting carried away with the feeler gauge. I did mine at 80,000 all were in spec. but they were all over the place, some lower end of the scale, some high end. They have such a large tolerance a blind man could get them in the ball bark. Between the matched injectors and the valve lash the engine is way smoother and quieter now.
Old 11-24-2003, 09:48 AM
Re:valve adjustment
yes sir,
there was a large discusion on this a while back and most of us are running them much tighter then the book sas to with good results. (acouple thou under the min no.)
Old 11-24-2003, 08:32 PM
MCummings's Avatar
Re:valve adjustment
.08 and .180 is where I set mine.
This should help a little.
http://www.dodgeram.org/tech/dsl/val.../12_valve.html
Merrick
Old 11-25-2003, 05:11 PM
20014x4's Avatar
Re:valve adjustment
thanks for the help. everything was within tolerance.
Fishbait
11-23-2009 11:21 AM
ConnerCop
05-05-2009 07:48 AM
dhughe2
13
12-06-2006 07:40 AM
bulthisl
03-22-2003 07:01 AM
blackboat
11-08-2002 06:32 PM
Quick Reply: valve adjustment
