Valve Adjustment?
Valve Adjustment?
My buddy just picked up an 04 with very ypoor injectors (won't start...), he has ordered new ones and while he is in there he wants to adjust the valves. I didn't know you still had to do that on the newer ones... anyway, I said I would have a look and see what they need to be adjusted to, does anybody have those clearances handy? thanks ahead.
X's 2, i think the clearances are in the book. i just did mine called the shop to get the numbers. minus the injector install... not to bad. the back two cylinders are kinduva b!tch. i think a valve lash is recommended every 60k??
Post-R&R lash adjustment is recommended, but not required if you make sure all the bits & pieces go back where they came from... we do it just to get a little more action out of the cam.
On an 04, I think recommended service is at 100K but I did mine at 65K and found they were getting close to max lash, esp on the intakes. IIRC the manual says you can have .015 on the intakes and mine were all at .013 or .014. Exhausts can be .035 and I had .028 to .030. Anyway, I went ahead and adjusted them all to .010/.020. It gave me a small improvement in mileage (maybe .5 MPG) so as long as you're in there, I'd say go ahead and do it.
Fishbait
11-23-2009 11:21 AM
blackboat
11-08-2002 06:32 PM
