Valet Switch Install
Old 04-26-2004, 02:50 PM
signature600's Avatar
Red face Valet Switch Install
Installed my Valet switch from PDR this weekend. Here is a warning for everyone wanting one:
WAIT UNTIL AFTER YOU GET INJECTORS BEFORE INSTALLING ONE!
With the switch off, my truck feels worse than stock, which is not bad for the clutch, but after driving with a #8 for about 8 months, it is terrible .
Anyway, How do you get more power while in valet mode?
Injectors, DV's.
Anything else?
Thanks,
Chris
Old 04-26-2004, 02:57 PM
BigBlue's Avatar
I thought valet mode was supposed to kill the power.
Old 04-26-2004, 03:02 PM
It does.
With the switch on; It is the same as it has been for the past 8 months.
With the switch off; No air gets to the pump, and power is reduced, DRASTICALLY.
It is pretty cool though, Get one of your buddies in the truck and drive in valet mode, then tell them "Hey, flip that switch when I shift" Then lay into it. .
They think it's Nitros or something!
Nothing but #2 for me, maybe some water down the road.
Chris
Old 04-26-2004, 03:55 PM
Muted User
Forrest's Avatar
I just did a Reno to Sacramento & back this weekend, all Valet switch. That's over the Sierras, 7200' elevation, all the way down to 100' elevation. Well ... flipped in on 3 times, only to test boost & get on 2 on-ramps.
Anyway, sure makes a big difference, huh? Neat though ... just try & make it smoke.
I'm gonna run a tank all around town / commute & see what the mileage does. The trip over the Sierras & back netted 20mpg w/plenty of power, even up the steepest hills.
Old 04-26-2004, 07:25 PM
jman's Avatar
signature600 i see you have a 95 so thats telling me it work with a 98 12 valve, ok where do i get one and how hard is it to install thanks
jman
Old 04-27-2004, 05:57 AM
I got mine from Piers, and it took two of is about an hour and a half. He wired while I did the under hood work. The hardest part is loosening and tightening the fitting on the intake manifold, pretty tight space. The instructions are pretty good but leave out a few things.
Bottom line is, IF I CAN DOI IT, ALMOST ANYONE CAN!
Chris
BTW, It might have gone faster if there hadn't been about 4 high shcool girls running around the shop distracting us , (my little brother was working on his truck and had all his friend there.)
Old 04-27-2004, 10:17 AM
Jim Fulmer's Avatar
Mine looses 200 HP in Valet.
Jim
Old 04-27-2004, 10:30 AM
Lil Dog's Avatar
Old 04-27-2004, 11:36 AM
Dr. Evil's Avatar
Jim
Im barely making 200 HP....
Old 04-27-2004, 01:35 PM
OK, apparently we are confused on ON and OFF.
My ON means: Boost is passing through the valve and to the pump.
My OFF means: Valve is closed, NO boost going to pump.
I hope this clears up the confusion,(I'm tired of getting "funny looks and responses)
Thanks Guys,
Chris
Old 04-28-2004, 11:09 AM
98rammer's Avatar
doh, i'm having a brain fart--who's the member with the variable valet?
Old 04-28-2004, 08:35 PM
Re: Valet Switch Install
Injectors, DV's.
Anything else?
[/B]
With all these "Good" replies I haven't gotten an answer for this question.
Come on, I know you guys will help me out(please).
Thanks Again,
Chris
Old 04-28-2004, 08:58 PM
Jim Fulmer's Avatar
You are correct, pump is at no boost fuel so what ever it's set at with no boost is all you get, now add injectors and/or DV's and you gain power from there.
Jim
Old 04-29-2004, 07:59 AM
Thanks Jim, I knew you would help.
Old 04-29-2004, 11:50 AM
calls's Avatar
Could one of you please explain to me just exactly what this valet switch is? I don't understand what it is that it does and why?
Quick Reply: Valet Switch Install
