Vacuum pump gear help
Old 04-16-2009, 04:02 AM
LanceD's Avatar
Does anyone know the size of the vacuum pump shaft and the taper on it? also the keyway?
Old 04-18-2009, 06:31 PM
LanceD's Avatar
no one has a vacuum pump pulled who can measure for me?
Old 04-21-2009, 02:46 AM
LanceD's Avatar
anyone?
Old 04-21-2009, 08:23 AM
Mike D's Avatar
LanceD, I think my buddy has one sitting around at the shop. I'll see if can get some measurements for you this week.
Old 04-22-2009, 03:01 AM
LanceD's Avatar
woohoo! thanks!
Old 04-22-2009, 07:42 AM
Tate's Avatar
If you can wait till the weekend, I have one sitting on my shelf at home that I can take a look at. I'm 800km from there at the moment, though.
Old 04-22-2009, 08:46 PM
LanceD's Avatar
sounds good, I have been waiting for months already haha
Old 04-23-2009, 11:17 PM
Mike D's Avatar
Sorry LanceD. I dropped the ball on getting the measurements for you. We've been pretty busy getting a truck ready for Pinks All Out this weekend. Just wanted to let you know I haven't forgotten.
Old 04-24-2009, 12:50 AM
LanceD's Avatar
no prob, thanks for the update
Old 04-25-2009, 12:16 AM
Mike D's Avatar
.619 on the shaft diameter. Didn't have a gear puller handy so don't have any other measurements at this time.
Old 04-25-2009, 01:20 AM
LanceD's Avatar
Dang, I can't figure out which one it is. Im trying to replace my vac/ps pump with a dedicated high flow hydro pump to run a bunch of stuff. here are my options for shafts. which one do you think it would be?
Attached Thumbnails Vacuum pump gear help-shaft.jpg   Vacuum pump gear help-shaft1.jpg   Vacuum pump gear help-shaft2.jpg   Vacuum pump gear help-shaft3.jpg   Vacuum pump gear help-shaft4.jpg
Old 04-25-2009, 12:27 PM
1workinman's Avatar
oil pump
Sir I have wondered if the case back hoe or lull with the 4 cylinder cummins could have a oil pump that you wont. There may not be enough room in the dodge frame. The 780 case backhoe had oil pump on the end of the crank I think. It had 24 volt starter and a air pump to be used on the air brakes. Manual tack. good luck
Old 04-25-2009, 08:14 PM
LanceD's Avatar
I thought about running one off the front of the crank but there just isn't enough room up there for a pump.
Im going to run one thats 15GPM and a priority valve for the steering. the rest is going for a winch, on board air, and an on board welder. all hydraulic driven
Old 04-25-2009, 10:59 PM
jbone's Avatar
vacuum pump gear help
Contact Pete Gould at fixinrams.com. Pete is a major source of remanned vacuum pumps. A hydraulic pump without a large reserve tank and a recirculation circuit will burn itself up before driving 50 miles. There is a belt driven hydraulic pump available from Northern tool that can be turned on and off with an electric clutch like an a/c clutch; flip a switch for hydraulic service, flip a switch to turn it off. Just a suggestion.
Old 04-26-2009, 03:42 AM
LanceD's Avatar
I know, I plan on running a 10-15 gallon resivoir. basically a full blown hydraulic system.
jimbo486
05-08-2016 06:07 PM
4969joes
03-27-2010 08:58 AM
Quick Reply: Vacuum pump gear help
