vacumn pump trouble
Old 09-19-2011, 09:06 PM
whiteeye42's Avatar
vacumn pump trouble
hi i have a friend that has a 04 5.9 cummins and is having problems with the vacumn pump he had the pump replaced but the cruise control still will not stay enguaged he wants to know what all the vacumn pump controls and were he might look for a vacumn leak or what eles might be wrong with the cruise control Thanks in advance
Old 09-20-2011, 10:08 AM
infidel's Avatar
Easy way to tell if there is a vacuum leak is after running the engine shut down for five minutes then disconnect any vacuum hose.
It should hiss.
A system without leaks will hold vacuum for hours if not days.
Second most common cruise problem behind vacuum problems is a bad brake light switch. The switch has several sets of contacts, the brake lights can work fine but another set of contacts not.
Old 09-20-2011, 01:15 PM
whiteeye42's Avatar
ok thanks i will tell him to check the brake switch
Old 09-21-2011, 12:04 AM
Russ Roth's Avatar
I believe the cruise on an '04 is completely electronic with no vacuum involved.
Camarogenius
03-31-2007 09:04 AM
Mopar Kid
03-12-2007 11:23 PM
Bobcat698
04-17-2006 01:48 PM
Bobcat698
11-21-2005 09:19 PM
lenny
06-10-2003 09:27 AM
Quick Reply: vacumn pump trouble
