vaccum line question
Old 01-20-2009, 06:20 PM
adidasman23's Avatar
i found a vaccum line on my truck the other day that led to no where. it was on the drivers side of the motor and back by the map sensor. it was green i think with a one way valve on the end with a rubber elbow on it. does anyone know what this is. and it is ok haveing the rubber elbow on connected to anything. help me please
Old 01-20-2009, 07:29 PM
infidel's Avatar
It sounds like the vent for the front differential but usually it terminates on the passenger side behind the airbox.
Old 01-21-2009, 09:26 AM
No the vent for that is just a rubber hose with a cap on it. This is a plastic line that is just like the line comming off the pump
Old 01-27-2009, 10:24 PM
ok. i think i found what the line goes to. i think its the 4x4 vaccum line. where does it plug in at.
Old 01-27-2009, 11:28 PM
thumper549's Avatar
I have one hahging there too !! But the 4wd works
Old 01-28-2009, 12:40 AM
jnicewan's Avatar
i think its the vac vent line for the 4x4. the check valve is on it so it stays shut untill vented.
Old 01-28-2009, 09:27 AM
Well my 4x4 doesn't work so I say it's the supply line
Old 01-28-2009, 09:49 AM
sheriffav8r's Avatar
The green one is the vent line. Red and black go to the CAD on the front axle. White is the supply line from the vacuum pump. The left line facing forward on the CAD sucks 4WD on, the right line sucks 4WD off. In a politically correct, non-gender biased sort of way, of course....
Old 01-30-2009, 02:02 PM
TIMMY22's Avatar
If you're having any type of trouble with the CAD operation, I would recommend the Posi-Lok cable kit.
I have one on my truck due to faulty vacuum lines that I didn't have the patients to trace out or risk of other problems later.
Pull the cable out, 4X4 on. Push cable in, 4X4 off. It's that simple.
Old 01-30-2009, 06:24 PM
infidel's Avatar
Mine must be segregated, they're all black.
klineta89
01-01-2011 04:21 PM
RichN
07-15-2010 07:11 AM
93-12Smoke
03-20-2009 07:20 PM
sleepr tsi
09-14-2008 01:39 PM
7421f
04-13-2006 06:57 AM
Quick Reply: vaccum line question
