Using no clutch
Old 10-13-2005, 06:36 PM
OilBrn's Avatar
Using no clutch
Does anyone else ever shift without the clutch, I used to drive semi's like that so I tried it with my new nv5600, and it shifts great like that if you let the rpms drop about 400 before grabbing the next gear, and it will fall right in.It will probably be real smooth when it loosens up.
Old 10-13-2005, 06:39 PM
Andy505's Avatar
I have driven my truck like that, but I'm not perfect and I cant always time the shifts right, so then I grind gears. People around me driving probably thought I didnt know how to drive a stick. So after a few days I started using the clutch again. Much easier for me.
Old 10-13-2005, 06:44 PM
blowin smoke 03's Avatar
I drove 4 hours back from a truck pull in Memphis Tenn to Eva Alabama without a clutch when the hyd. for the clutch broke and that was enought for me,I like using my clutch!!!
blown32's Avatar
Yup, sometimes I do clutchless shifting. Not ofter but it is very smooth if I am not in a hurry.
Old 10-13-2005, 07:10 PM
AirGrabber's Avatar
The 1st and 2nd gens were alot nicer to shift without a clutch. The new common rail seems to like to "hover" awhile till the rpms drop. On level ground there not to bad, on any incline you loose to much momentum waiting for the rpm to drop. The older ones (gassers also) Had a quicker drop with a mechanical set up. Alot of truck drivers use there jake to keep the momentum while upshifting.
Old 10-13-2005, 07:44 PM
Mike_Boutet's Avatar
These tranny's aren't meant to be shifted without using the clutch. It's hard on the syncros. There was a good discussion on this a while back with excellent discriptions.
Old 10-13-2005, 08:30 PM
gsbrockman's Avatar
Isn't that what 48RE's are for ?
Old 10-13-2005, 10:09 PM
Buckshotmckee's Avatar
Clutch? Is that what that extra pedal is down there for? I only use to get moving.
Old 10-17-2005, 06:30 AM
danshsss's Avatar
I only use the clutch for taking off and speed shifting..I think I will break something in the trans before the syncros wear out
Old 10-18-2005, 12:35 AM
big red psd cc's Avatar
It all depends on the mood I am in. Sometimes I clutch, other times, just mesh them up
Old 10-18-2005, 03:28 AM
tenbrooks's Avatar
These transmissions are not designed to shift like that, you'll break your synchros and wish you hadn't. I know, I tore up a good transmission trying to look cool. heard it snap when shifted after that 4th would grind even when I used the clutch. lost $1600 in that deal
mknittle
05-11-2014 09:27 PM
JBradley500
06-25-2010 04:32 PM
PapaSmurf
04-04-2007 05:00 AM
jasonjones
26
05-02-2005 11:55 PM
Holiday
04-04-2005 07:07 PM
Quick Reply: Using no clutch
