Using existing exhaust for single stack set up?
Has anyone used their existing exhaust pieces for the plumbing up to and out of the bed for a single stack set up? What I mean is, has anyone cut up the piece that routes over the axle to get up through the bed? I already have my stack pipe just need to get it all routed to the bed.
If you have a shop saw you can make the elbows yourself. cut a 45* angle on each piece, weld em together, and you have a 90*. I had to make 2 of mine that way. Depending on if you put your stack in the middle or to the side will change the pipe you need. If you go straight up from the exhaust, you just need one elbow. If you go to the corner it can be tricky. I had to go behind the front bed support and then come forward with my pipe. Took a little cutting and welding but not too bad.
Uploaded these. First pic is facing from the front of the truck back. You can see the welds. And I thought i had made 2 90's, but i only made one as you can see.
Valv
08-05-2007 12:51 AM
sluggo42
11-21-2006 03:12 PM
95RAM111
11-11-2003 02:32 PM
Blast54
11-02-2003 01:46 AM
