used vp pump?
Old 08-15-2010, 05:36 PM
DieselNomad's Avatar
used vp pump?
i managed to find a used pump from a roll over out of a 2001, i am assuming that this pump is the same for all model yrs that used this particular vp pump.or is there diff. pumps for diff yr of trucks?is there anythinbg on the pump in the way of a serial number or some other means to verify that this pump will work in my rig?i would like to be able to verify that this pump works before buying it!hopefully this will get me back rolling even if its only a temp. fix.thanks fellas!
nomad
Old 08-15-2010, 07:18 PM
bowhunter57's Avatar
Location: I live in Bernville Pa but where I want to live is Colorado
VP Pump
If yours is automatic or 5 speed an the one you found is the same and NOT A 6 SPEED then you should be good to go, or if yours is a 6 speed and the one you found is a 6 speed then your good to go that way
I almost forgot if you get this pump before installing make sure the key is the same # as yours. I just replaced mine and the key was a #036 and the arrow on the key MUST FACE THE PUMP i don't know why but they say it must.
Old 08-15-2010, 07:30 PM
i will have to make a call, but i think it might be coming out of a 6 speed. not starting to sound to good. so for some reason an auto and a stick are diff. pumps?
Old 08-15-2010, 07:39 PM
Just the 6 speed is differant the AUTO AND THE 5 SPEED ARE THE SAME PUMP the 6 speed is a HIGH output pump
Old 08-15-2010, 07:51 PM
Junk Man's Avatar
Call a rebuilder. I read where one pump could be used on both HO & SO engined. I don't know the details but bluechip or mwfi would .
Old 08-15-2010, 07:59 PM
scottsjeeprolet's Avatar
You can use an SO pump on a HO engine but not the other way round.
hitcb1789
05-25-2010 09:10 AM
gozapper
03-03-2008 07:09 PM
Mcmopar
12-06-2006 11:23 PM
v8440
06-30-2006 01:44 PM
peanut
11-16-2004 03:46 PM
Quick Reply: used vp pump?
