used injectors
used injectors
is it safe to run a set of used bully dog injectors with 10,000 miles on them? is there anything that could go wrong with them? thanks in advance for your help!
Don't be scared of used injectors, just have them tested before you install them. I bought a set of used injectors out of the classifieds on here. They worked great, and I've had no problems at all with them.
Yes an injection shop can test them. I know a guy at my local dodge dealer, and he tested mine. He checked the pop-off pressure, spray pattern, and if they dribbled.
i bought the bd 3's from a reputable diesel shop. he said the guy drove the truck in and he installed larger injectors for him. he said there was no reason to have them tested. if i install them and the pop-off pressure, spray pattern, or if they dribble,will i be able to tell?
hitcb1789
05-25-2010 09:10 AM
southernsmoker
04-06-2004 02:05 PM
