How to use timing pin on pump
what is the purpose of the slotted end of the timing pin?
Is the slot suppose to fit over something flat (edgeways)?
Should I insert the pin and rotate it until it slides over something flat ?
Thanks, Tom
Thanks, Tom
I suspect you are looking for this: http://www.dieselcare.net/P7100_Inst...structions.pdf
This for the VE pump: http://gnarlodious.com/Vanagon/Bosch_Pump/-Rebuild.html
Same pump, different engine application, but the timing pin is the same.
I think he's looking at the other timing pin on the side of the pump.
This should explain it> http://www.cumminsforum.com/forum/94...ack-stock.html
Crossy's son
09-01-2009 09:46 PM
wvopowered
07-07-2008 12:20 AM
