Updated timing gear torque spec
Old 12-01-2003, 08:55 PM
dave0415's Avatar
I am working from a five year old Chilton book, and have looked around DTR for the updated torque spec with no luck can someone post it for me.
Dave
Old 12-02-2003, 07:17 AM
bulthisl's Avatar
Re:Updated timing gear torque spec
Old = 144 ft. lbs.
new = 160 ft.lbs.
There ya go ! ;D
: Eddie : 8)
Old 12-02-2003, 07:50 AM
MnTom's Avatar
Just remember to clean the pump shaft AND the inside of the gear before reassembly. Also make sure they are dry too. Something like BRAKLEAN works fairly well.
Tom
Old 12-02-2003, 10:42 AM
dave0415's Avatar
Thanks for the specs. Brake cleaner is one of my SOP items. ;D
Dave
Old 12-02-2003, 02:44 PM
bulthisl's Avatar
Or you can use starting fluid and finish the job with a smile. ;D
: Eddie : 8)
Old 12-02-2003, 05:07 PM
RCW
RCW's Avatar
I use blue loctite and set at 150 foot lbs. The loctite lubes the threads and results in the same torque as the 160 lbs dry. I have never had one come loose with the loctite either.
Old 12-02-2003, 08:41 PM
bulthisl's Avatar
I forgot I also use blue loctite.
But I still Tq. 160.
: Eddie : 8)
finndogg54
03-31-2010 07:07 PM
Banzai Bob
02-03-2004 10:09 AM
bkay
10-16-2003 02:22 PM
MLR1
08-21-2003 10:09 AM
1stGenBikeHauler
01-25-2003 12:31 PM
Quick Reply: Updated timing gear torque spec
