UH OH! Something gone very wrong...kdp?
Old 01-03-2010, 02:06 PM
MoPowa's Avatar
Well I thought it was my turbo that seized and stopped my engine from running....I hooked my charger up to the truck this morning and it started to crank than I heard something lock, immediately trying to crank again was difficult for the battery. Turbo is disconnected from intercooler as well. Im going to continue charging the battery and see if it will try turning but I fear the worst.....
Could this be what I think it is? I sure hope not...EDIT
It seems strange how it slowly became a bad problem, which is what lead me to the turbo, I swore I even heard noises from the turbo off boost, when it was getting boost the noise went away....but now with everything disconnected and free, the turbo looks good and something sounds like its seized.
Old 01-03-2010, 03:52 PM
Heavyduty1's Avatar
If you can spin the turbo's wheel by hand it aint siezed. If your batterys weak it could be causing the starter soleiniod(sp) making a clicking noise.
P.S. A little loose motion up/down on the turbo wheel is fine but if the wheel is hitting the turbo housing you may be replacing the oil seals soon.
Old 01-03-2010, 04:00 PM
mullishacrew's Avatar
can you take a breaker bar and a socket on the dampner bolts and rotate the motor?
Old 01-03-2010, 04:07 PM
the 93 did the same thing, it would turn over and make like an abrupt nasty sound, turned out the battery was too dead
Old 01-03-2010, 06:31 PM
dzl_damon's Avatar
Ditto on my 89. Like, almost machine gun fire from the solenoid engaging and disengaging I was guessing. If he battery is really bad, the charger won't rectify it either. I hooked up another truck's battery and it was good to go.
Old 01-03-2010, 06:45 PM
MoPowa's Avatar
Well I found out what it was. Turbo is fine, its definitely not the Dowel Pin, nothing internally is stopping it from cranking over fast enough to start. On my inspection of the oil in the bottom of the pan I noticed a bunch of aluminum filings underneath the tranny laying on the ground. Sure enough I took the service cap of the bottom to expose the flywheel and a pile of aluminum filings fell out as well is a couple chunks of steel. I have pictures but have figured out how to post pictures yet.
At least the flywheel is cheap though....its just finding a good shop who will do it cheap and fast....LOL Tempted to buy a good convertor and throw it in while its apart
Old 01-03-2010, 07:14 PM
Ow. Glad to hear it's nothing terminal.
Old 01-03-2010, 07:16 PM
Good excuse for a better 2nd gen flexplate and a tight torque converter
Same thing i said in another thread tonight....LOL
But yea don't buy a stock 1st gen flexplate, a 2nd gen flexplate is like $120 and is much stronger
Old 01-03-2010, 10:03 PM
dzl_damon's Avatar
Ha... thought I read that somewhere else tonight
I was gonna say the flexplate (not flywheel) is pretty cheap, and not too too hard to install I think.
Old 01-03-2010, 10:47 PM
Benjamin b2's Avatar
since its not to hard, will you do mine, i mean all you have to do is pull the tranny.
Old 01-03-2010, 11:04 PM
MoPowa's Avatar
My thoughts exactly, I think I will opt for a second gen "flexplate" when I get it taken to a shop. I wish I was back home, this normally would have only cost me time and a case of beer.....
Old 01-04-2010, 01:22 AM
Crazy Matt's Avatar
What did you break now????
cbrahs
11-01-2011 11:00 AM
Smokin96_12v
10-12-2009 07:39 AM
qwest
07-28-2007 05:12 PM
micstep
03-06-2005 10:08 PM
Patrick Campbell
08-20-2004 01:07 PM
Quick Reply: UH OH! Something gone very wrong...kdp?
