Uconnect quit Working...
Old 01-13-2008, 09:11 PM
drdodge's Avatar
Unhappy Uconnect quit Working...
I have a factory installed Uconnect that not longer work, It start that when i push the mirror button the radio display (CELL) but no audio hear in the speakers, i suspect for a loose connection and disconnect the radio and check the connectors , everything looks find. Reassemble and now its not working at all.
Any Ideas!!!
Old 01-13-2008, 09:41 PM
sweeney186's Avatar
Sounds like the u connect module--behind r side dash end cap
Old 01-14-2008, 08:23 AM
drdodge's Avatar
I will take the module out to check...
Could it be something that need dealer reprogramming ??
Old 01-14-2008, 08:41 AM
sweeney186's Avatar
It should not need to be reset-module failure is not uncommon
Old 01-14-2008, 06:26 PM
drdodge's Avatar
Take the module out!
Take the module out, everything looks ok...connectors Ok, and no obvious damage in the module.
1- would reading the OBDII will give me a failure???.
2-Could disconnecting the radio without disconnecting the (-) battery cable could cause this.?
3- is there a way to reset the module?
Old 01-14-2008, 09:29 PM
sweeney186's Avatar
No,sorry but module failure is common
jam1on1
07-21-2005 12:40 AM
05DodgeRamGlenn
05-26-2005 01:37 PM
NJMurvin
08-20-2004 11:22 PM
Buff1147
04-17-2004 07:49 AM
belfert
10-31-2003 01:51 PM
Quick Reply: Uconnect quit Working...
