U gotta love em
Old 01-03-2010, 09:42 AM
Boatnik's Avatar
U gotta love em
I got to the hunt club Wed. and the check engine light came on for the third time in a week. Battery voltage was down and lights were dim. I parked the truck and went on the morning hunts. Got back in the truck at noon and the altenator refused to charge. I massaged the altenator with a stiff rap of an adjustable spanner and it started charging. It continued charging all the way home. I pulled the altenator apart and just as I hoped, the brushes were worn out. However, I could not find a set of brushes anywhere. I had to replace the whole altenator.
The good news is it was a very easy repair. That has been the case on most things I have done on this truck. I think would rather push a first gen than ride in any thing else. Except maybe a KW.
Old 01-03-2010, 10:15 AM
Whats this "check engine light" you speak of and where is it ?????
good story
Old 01-06-2010, 09:50 PM
Boatnik's Avatar
Big red letters that light up on the dash that mean UH OH! You aren't watching your gauges very well.
I get so complacent driving this truck I forget that things can go bad at times. I periodically check under the hood and I keep a close tab on tire pressure but once I get moving it just keeps going like the EverReady Bunny.
Even at nine volts on the gauge the shutdown solenoid stayed open. I have had mishaps with this truck that would kill a lesser vehicle and came out without a scratch. U gotta love em.
Old 01-06-2010, 10:15 PM
366 Spring Chicken
Richie O's Avatar
Im pretty sure geno's has the alternator brushes. I know its not easy to wait for days to have them delivered. When I worked at a parts store years ago a few people would rebuild there own stuff. We sold some brushes and some starter bushings, drives. It seems harder to find those parts now.
Old 01-06-2010, 10:23 PM
1985cucv's Avatar
genos does have an alt rebuild kit its like 35 bucks
Old 01-07-2010, 08:30 AM
sooty's Avatar
alt
i pulled mine apart to do the same, only to reveal the copper segements were worn 3/32" deep, exchanged for autozone life'er, warranty will give replacement anywhere it might permaturely fail, and yes the brushes are availabe, your local auto parts store's rebuilder will furnish them
Old 01-07-2010, 11:27 AM
Rick 12v CTD's Avatar
My truck doesn't have the check engine light. In its place I have the gate open light. How sad.
Old 01-07-2010, 01:52 PM
Advance auto still sells the brush kits to rebuild the GM alternators, Stock and aftermarket..... I just bought a kit actually to up my wattage to 240 amp ....hopefully my little small block will turn the big bad alternator to power my 2 big bad amps behind my seat
Old 01-07-2010, 08:41 PM
CONFEDERATESON's Avatar
its off topic but you could get a capasitor brandon to keep a constant supply of juice to your amps. it will keep your subs happy and make them hit harder if you have them set up right...and just currious why would you have 2 amps?
Old 01-07-2010, 08:46 PM
2 amps,
My 4 frontish speakers are hooked to an amp and my 2 rear speakers hooked to the same amp the 2 12's are hooked to.
hahaha alot of system in a regular cab....
I've never heard anything good about a crapacitor...the audio nerds on my chevy forum said they're a joke because you're already running power straight off the battery
Old 01-07-2010, 09:03 PM
SmokemS's Avatar
he can't watch the gauges.....he is not allowed in the driver seat.....haha sorry brandon had to
Old 01-07-2010, 10:44 PM
justin mcfall's Avatar
Now that was priceless!!!
Old 01-08-2010, 06:08 AM
Boatnik's Avatar
It must be a local thing here but, I called all the different part stores in my area within 25 miles. Auto Zone was the only place that had any listed and the supplier was out and no longer available. Pep Boys was the cheapest and it has a lifetime limited warrenty. I thought about up grading to a higher output but decided 120 amps was enough for my stock radio. I won't be putting in any high powered amps. My hearing is bad enough as it is and I won't give up the gun rack behind the seat.
Old 01-08-2010, 06:20 AM
I'm allowed there just not by myself
Old 01-08-2010, 07:41 AM
boostedve's Avatar
2 amps,
yo brandon what subs and amp you have, back in 1999 i was the worlds loudest in my class with 4 12in kickers and 8 kicker 1200.1 did 165db...
Forrest Nearing
39
11-09-2004 07:24 PM
Mexstan
09-16-2004 02:03 AM
ramlovingvet
09-14-2004 12:18 PM
10-26-2003 03:34 PM
DarrellB
10-24-2002 09:37 AM
Quick Reply: U gotta love em
