types of fuel pressure gages
Old 10-26-2003, 07:16 AM
dhe9's Avatar
ok, it is time to install a fuel pressure gage. my question is this. are there different types of gages such as mechanical or electrical? if so what would be the best to install on my truck? i will not do it but get it done. just want to ensure i have what is best. also what brand do you wrenches recommend?
thanks,
david
Old 10-26-2003, 07:37 AM
Administrator / Scooter Bum
Shovelhead's Avatar
Re:types of fuel pressure gages
You will get responses from all sides on this as it is a personal preference.
I'm using an Isspro EV series mechanical gauge installed on the dash plumbed with high quality stainless steel braided line.
It's simple, and there are no senders to go bad.
Others prefer electronic gauges to avoid the "fuel in the cockpit" scenerio.
Then you'll get into digital vs analog ie number readout vs needle sweep.
Then you'll have the where to mount it question.
Check out a few trucks at your next get together and see what works for you.
Mine came from www.wildcatdiesel.com
Old 10-26-2003, 08:59 AM
Racer57's Avatar
What ShovelHead said. I run like he does (I think). Isspro Marine gauge in cubbyhole with 6' SS braided line coming off of the bottom of the fuel filter cannister. No isolator, no noise, no problems. Simple is as simple does. Also got mine from Rod at wildcat. I have heard problems tho with those who put a mechanical gauge on the A pillar with noise. Cubby is the best place. You don't need to look at it all of the time.
Old 10-26-2003, 09:52 AM
dhe9's Avatar
racer57,
what do you mean the "cubby hole?" is that the space in the dash?
Old 10-26-2003, 10:16 AM
Racer57's Avatar
Yes, that worthless opening in the dash. Eric Buckle or is Buckel makes a really neat plate and he will pre-drill it for you.
http://www.turbodieselregister.com/c...uery=retrieval
Old 10-26-2003, 10:20 AM
remarc31's Avatar
What pressures are you looking at between a new filter pressure and when it's time to change due to high pressure due to plugging.
Old 10-26-2003, 10:44 AM
Racer57's Avatar
Don't know for sure. There are others out there that run both a pre and post filter and change filter accordingly when there is a noticeable drop in PSI. Prolly around 2psi I'm guessing. Myself, I change mine every 7,500 miles. $12.20 each is cheap insurance as far as I am concerned.
Old 10-26-2003, 10:47 AM
Shovelhead's Avatar
Once you install it, you'll get a feel for what is "Normal" on your truck.
If you see pressures drop off too much, change the filter.
kryptonight07
01-07-2011 11:39 AM
boughta1990w250
30
01-24-2010 11:06 AM
EverydayDiesel
06-06-2007 07:39 AM
greatwhite
02-04-2005 07:44 AM
apache
11-09-2003 02:19 PM
Quick Reply: types of fuel pressure gages
