Two Engine Codes
Old Jan 2, 2006 | 10:39 AM
2002RAM's Avatar
Two Engine Codes
My truck felt like you were tapping the break while excelerating and the engine light came on. Codes: P0112 & P0237. Now when I drive it it feels like a diesel with no turbo. I can hear the turbo whind up but no power. I think that the wastegate or blow off it stuck open and not going into the engine. Am I thinking wrong? How do I fix it? (Only mod: AEM brute intake, no chip)
Old Jan 2, 2006 | 10:46 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Both of those codes are boost related.
You have a loss of boost somewhere, check your intercooler boots to see if one popped off or has a hole in it. Sometimes an AC line will rub against it causing a hole, or one has come loose.
Old Jan 3, 2006 | 03:28 PM
2002RAM's Avatar
I am wondering if it could just be a dirty fuel filter. Thoughts?
Any tips on changing the fuel filter?
Old Jan 3, 2006 | 04:57 PM
BigBlue's Avatar
P0112-Intake Air Temp Sensor Voltage To Low
P0237-Map Sensor Voltage To Low
Like Lary said, check your intercooler boots and make sure none of them are loose or broke.
Old Jan 4, 2006 | 09:33 AM
2002RAM's Avatar
I checked the boots and they are fine. Changed the fuel filter and nothing changed. Then disconnected the boot that connects to the arm to the intercooler right before it goes into the engine, and let it run. It was throwing air like mad. Could it be the lift pump? Is that the VP44 that everyone talks about. (Sorry I'm so new)
Old Jan 4, 2006 | 12:21 PM
2002RAM's Avatar
My guy told me that the MAP sensor was bad. Anyone know if this could cause a power loss in the engine?
Old Jan 4, 2006 | 01:10 PM
roadranger's Avatar
Yes.
You've also got a code for the IAT (Intake air temp sensor) which may need replacing too.
Old Jan 4, 2006 | 01:26 PM
crobtex's Avatar
I don't know where you are, but go to a Cummins dealer. Should be less then $100 for both sensors.
Look here to see where they are located:
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
Old Jan 5, 2006 | 06:52 AM
Joe Diesel's Avatar
I got the same code P0112-Intake Air Temp Sensor Voltage To Low, but I havent seen or heard any symptons, turbo spools up no prob. Engine light is still on, I'm waiting til it clears itself dont wanna pay DC $100 for 15sec of work.
seldomseen
Dec 3, 2010 09:50 AM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
