Twins Question...?
Old 08-14-2007, 10:30 AM
Muddin_dude06's Avatar
Twins Question...?
Hey everyone I fabbed up a hotpipe a while back for an HX35 and BHT3B twinset using junked turbos. I am kind of thinking about running that setup once I get the new HG settled in and see what kind of HP I can produce for now and have great drivability.
My biggest question is with a ported out and polished head (removed as much material as possible on everything I could) and a PDR cam what kind of RWHP could I produce with an HX35 (14cm WG housing ported) and a BHT3B (23cm housing ported) twinset? And what kind of boost should I be able to maintain without having too much drive pressure?
On the HX35 I am going to open up the wastegate to about 35mm and drill the divider to wastegate all six cylinders, and was probably going to add a 44mm external wastegate to the hotpipe to bypass the 23cm housing.
But thanks to everyone for your input!
Old 08-15-2007, 09:07 AM
Any ideas ya'll?
Old 08-15-2007, 10:04 AM
HOHN's Avatar
I can't really tell you much other than this:
The 35/3b twinset has been taken to over 700hp, IIRC, though it was a long time ago. Jim fulmer originally ran that twinset.
But to get to that level, he had larger housings-- 18.5 on the 35 and a 26 IIRC on the 3b.
Count on a huge WG or larger housing on the 3b if you want to make bigger power.
I'd say you have enough fuel for 600+, but I don't know anything about 12V, and that would just be a WAG.
Old 08-15-2007, 10:08 AM
ratsun's Avatar
Harry from PDR hit just shy of 700 with a 35/14 and a 3B/26
He also has a ported head and one of their cams
Old 08-15-2007, 02:38 PM
thekidfan's Avatar
Formerly of PDR!
Old 08-15-2007, 02:42 PM
HOHN's Avatar
You means Piers? Or Harry?
The fact the Piers' last name is also the first name of another PDR employee get's AWFULLY confusing!
Old 08-15-2007, 04:06 PM
RonA's Avatar
He's talking about Harrys truck, not Piers.
Old 08-17-2007, 05:54 PM
thekidfan's Avatar
Harry's truck "1HOTRAM" is the truck that went over 700 with a 35/3b combo. And neither Piers nor Harry are with PDR any longer! Although both are doing very well shared a few with Harry just last week , no not coffee
Old 08-17-2007, 06:29 PM
Clucker's Avatar
you know I had a suspicion since the guy I spoke with last week was an asshat, Harry was at least nice about telling you he had no idea about the question at hand......
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
stlsparky
11-21-2005 10:02 PM
Quick Reply: Twins Question...?
