Twins EGT s
Old 02-16-2008, 06:20 PM
txdodge97's Avatar
Twins EGT s
what are your cruising and idle egts with twins?
Old 02-16-2008, 06:36 PM
RonA's Avatar
Idle at 300. 65mph on flat ground is between 600 and 625deg. That's with Mach 4's, #100 plate in the middle and afc in the middle. No valet, 600hp at full throttle.
Ron
Old 02-17-2008, 11:09 AM
graphitecumnz's Avatar
Yup... mine will creep to 750 on a long unloaded uphill pull at cruising speed.
That's with BD twins.
Old 02-17-2008, 11:21 AM
ScottGregory's Avatar
Same here. Idle 300*, Cruising 550-600*, WOT on 5x5 will hit 1100*
Old 02-17-2008, 01:14 PM
heykw's Avatar
What would be the best set of twin to run on my 01 with the mods in my sig the egt's will only get down to 350 at idle and 1500+ at wot
Old 02-17-2008, 03:14 PM
I have been very pleased with the BD Twins as they are good for daily driving and playing. I plan on staying with them when I get done with my engine and it will be quite a bit stronger. There are much better sets for serious hp, at the potential loss of spool-up. Other are better qualified than I to speak on this matter.
The other thing I liked is that the kit had everything needed for the install.
Old 02-17-2008, 06:03 PM
heykw's Avatar
that is a nice feature
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
dodgediesel
17
04-05-2011 11:21 AM
jmccart
11-20-2006 06:45 PM
Stock 02
28
09-24-2006 11:09 AM
Quick Reply: Twins EGT s
