How to turn up the boost on an HX?
Old 01-09-2008, 06:53 PM
tex23455's Avatar
Just put on a HX and it is getting 18 psi. How do I open up the wastegate? Thanks guys.
Old 01-09-2008, 07:02 PM
Diesel Dummy's Avatar
you can get a adjustable boost elbow, a j hook or just unhook it all together, a boost elbow would be best, if you get over 35 psi you are out of the turbos efficiency range. DD
Old 01-09-2008, 07:13 PM
logskidder's Avatar
Adjust the rod for free.
Old 01-09-2008, 07:27 PM
tex23455's Avatar
How do I adjust it till it's loose or what?
Old 01-09-2008, 07:29 PM
hink's Avatar
http://cgi.ebay.com/DODGE-CUMMINS-TU...QQcmdZViewItem
Old 01-09-2008, 07:34 PM
tex23455's Avatar
On the HX it already has a external wastegate with a rubber hose can't I just clamp the hose or twist the bar on the HX.
Old 01-09-2008, 08:11 PM
logskidder's Avatar
Loosen the jam nut and turn rod end counter clockwise(to make the rod longer)if it doesnt have a jam nut you have to drill the 3 crimps,take the rod end off, install a jam nut, reinstall the rod end and set your boost. Its easy and its free.
Old 01-09-2008, 08:25 PM
tex23455's Avatar
Thanks logskidder. Thats what I needed to hear.
Old 01-09-2008, 08:33 PM
johnh's Avatar
to get more boost you need to keep the waste gate from opening
Old 01-09-2008, 08:47 PM
logskidder's Avatar
The only to keep it from opening is to plug the hose , weld it shut or use a j-hook. You can adjust the rod to get the boost(with in reason) you want and still have your wastegate work.
Old 01-09-2008, 09:00 PM
Big Blue24's Avatar
Shorten the rod for more boost, but a boost elbow is by far easiest way to control boost at 35 psi. Just drill and tap your current brass elbow with a small set screw to limit boost "signal"=air pressure going to actuator bulb diaphram that pushes rod and opens wastegate.
Old 01-09-2008, 11:26 PM
Tate's Avatar
You will need a small bleed off orifice after the set screw, otherwise, it will take longer to open the wastegate, but will still open at the same pressure.
Old 01-09-2008, 11:32 PM
NoSeeUm's Avatar
Most would attach a boost elbow, which is fairly cheap also.
If the rod is adjusted, it should be shortened. This will increase the tension on the waste gate making it harder to open.
Jim
Old 01-10-2008, 06:05 AM
Ph4tty's Avatar
Such an easy question and so many different answers. Here are some options:
Pull the elbow and use a 1/8 inch npt plug
block off the line
replace your elbow with an adjustable line
install a manual boost controller in the line
Old 01-10-2008, 11:57 AM
Big Blue24's Avatar
Ph4tty, you missed one:
Weld the wastegate shut!
Not a good option if you plan on lots of fuel and long turbo life.
Quick Reply: How to turn up the boost on an HX?
